สร้างปุ่มimport txt.file
02 ก.ย. 62 , 15:39:36
อ่าน 1598 ครั้ง
Earth
« เมื่อ: 02 ก.ย. 62 , 15:39:36 »
สอบถามErrorที่เกิดจากสร้างปุ่มimport txt fileค่ะ
สอบถามเออเร่อเกิดจากอะไรคะ โค้ดที่สร้างในModuleตามนี้ค่ะ
รบกวนช่วยหน่อยนะคะ (ห่างหายจากการเขียนไปนานเลยค่ะTT)
Option Compare Database
Option Explicit
'***************** Code Start **************
'This code was originally written by Ken Getz.
'It is not to be altered or distributed,
'except as part of an application.
'You are free to use it in any application,
'provided the copyright notice is left unchanged.
' Code courtesy of:
'   Microsoft Access 95 How-To
' Ken Getz and Paul Litwin
' Waite Group Press, 1996
Type tagOPENFILENAME
    lStructSize As Long
    hwndOwner As Long
    hInstance As Long
    strFilter As String
    strCustomFilter As String
    nMaxCustFilter As Long
    nFilterIndex As Long
    strFile As String
    nMaxFile As Long
    strFileTitle As String
    nMaxFileTitle As Long
    strInitialDir As String
    strTitle As String
    flags As Long
    nFileOffset As Integer
    nFileExtension As Integer
    strDefExt As String
    lCustData As Long
    lpfnHook As Long
    lpTemplateName As String
End Type
Declare Function aht_apiGetOpenFileName Lib "comdlg32.dll" Alias "GetOpenFileNameA" (OFN As tagOPENFILENAME) As Boolean
Declare Function aht_apiGetSaveFileName Lib "comdlg32.dll" Alias "GetSaveFileNameA" (OFN As tagOPENFILENAME) As Boolean
Declare Function CommDlgExtendedError Lib "comdlg32.dll" () As Long
Global Const ahtOFN_READONLY = &H1
Global Const ahtOFN_OVERWRITEPROMPT = &H2
Global Const ahtOFN_HIDEREADONLY = &H4
Global Const ahtOFN_NOCHANGEDIR = &H8
Global Const ahtOFN_SHOWHELP = &H10
' You won't use these.
'Global Const ahtOFN_ENABLEHOOK = &H20
'Global Const ahtOFN_ENABLETEMPLATE = &H40
'Global Const ahtOFN_ENABLETEMPLATEHANDLE = &H80
Global Const ahtOFN_NOVALIDATE = &H100
Global Const ahtOFN_ALLOWMULTISELECT = &H200
Global Const ahtOFN_EXTENSIONDIFFERENT = &H400
Global Const ahtOFN_PATHMUSTEXIST = &H800
Global Const ahtOFN_FILEMUSTEXIST = &H1000
Global Const ahtOFN_CREATEPROMPT = &H2000
Global Const ahtOFN_SHAREAWARE = &H4000
Global Const ahtOFN_NOREADONLYRETURN = &H8000
Global Const ahtOFN_NOTESTFILECREATE = &H10000
Global Const ahtOFN_NONETWORKBUTTON = &H20000
Global Const ahtOFN_NOLONGNAMES = &H40000
' New for Windows 95
Global Const ahtOFN_EXPLORER = &H80000
Global Const ahtOFN_NODEREFERENCELINKS = &H100000
Global Const ahtOFN_LONGNAMES = &H200000
Function GetOpenFile(Optional varDirectory As Variant, Optional varTitleForDialog As Variant) As Variant
' Here's an example that gets an Access database name.
Dim strFilter As String
Dim lngFlags As Long
Dim varFileName As Variant
' Specify that the chosen file must already exist,
' don't change directories when you're done
' Also, don't bother displaying
' the read-only box. It'll only confuse people.
    lngFlags = ahtOFN_FILEMUSTEXIST Or ahtOFN_HIDEREADONLY Or ahtOFN_NOCHANGEDIR
    If IsMissing(varDirectory) Then
        varDirectory = ""
    If IsMissing(varTitleForDialog) Then
        varTitleForDialog = "Please choose a Target File ..."
    ' Define the filter string and allocate space in the "c"
    ' string Duplicate this line with changes as necessary for
    ' more file templates.
    strFilter = ahtAddFilterItem(strFilter, "All File (*.*)", "*.*")               '   "Access (*.mdb)", "*.MDB")
    ' Now actually call to get the file name.
    varFileName = ahtCommonFileOpenSave(OpenFile:=True, InitialDir:=varDirectory, Filter:=strFilter, flags:=lngFlags, _
                    DialogTitle:=varTitleForDialog)
    If Not IsNull(varFileName) Then
        varFileName = TrimNull(varFileName)
    GetOpenFile = varFileName
Function ahtAddFilterItem(strFilter As String, _
    strDescription As String, Optional varItem As Variant) As String
' Tack a new chunk onto the file filter.
' That is, take the old value, stick onto it the description,
' (like "Databases"), a null character, the skeleton
' (like "*.mdb;*.mda") and a final null character.
    If IsMissing(varItem) Then varItem = "*.*"
    ahtAddFilterItem = strFilter & _
               strDescription & vbNullChar & _
               varItem & vbNullChar
Private Function TrimNull(ByVal strItem As String) As String
Dim intPos As Integer
    intPos = InStr(strItem, vbNullChar)
    If intPos > 0 Then
        TrimNull = Left(strItem, intPos - 1)
        TrimNull = strItem
'************** Code End *****************
Function ahtCommonFileOpenSave( _
            Optional ByRef flags As Variant, _
            Optional ByVal InitialDir As Variant, _
            Optional ByVal Filter As Variant, _
            Optional ByVal FilterIndex As Variant, _
            Optional ByVal DefaultExt As Variant, _
            Optional ByVal FileName As Variant, _
            Optional ByVal DialogTitle As Variant, _
            Optional ByVal hwnd As Variant, _
            Optional ByVal OpenFile As Variant) As Variant
' This is the entry point you'll use to call the common
' file open/save dialog. The parameters are listed
' below, and all are optional.
' In:
' Flags: one or more of the ahtOFN_* constants, OR'd together.
' InitialDir: the directory in which to first look
' Filter: a set of file filters, set up by calling
' AddFilterItem. See examples.
' FilterIndex: 1-based integer indicating which filter
' set to use, by default (1 if unspecified)
' DefaultExt: Extension to use if the user doesn't enter one.
' Only useful on file saves.
' FileName: Default value for the file name text box.
' DialogTitle: Title for the dialog.
' hWnd: parent window handle
' OpenFile: Boolean(True=Open File/False=Save As)
' Out:
' Return Value: Either Null or the selected filename
Dim OFN As tagOPENFILENAME
Dim strFileName As String
Dim strFileTitle As String
Dim fResult As Boolean
    ' Give the dialog a caption title.
    If IsMissing(InitialDir) Then InitialDir = CurDir
    If IsMissing(Filter) Then Filter = ""
    If IsMissing(FilterIndex) Then FilterIndex = 1
    If IsMissing(flags) Then flags = 0&
    If IsMissing(DefaultExt) Then DefaultExt = ""
    If IsMissing(FileName) Then FileName = ""
    If IsMissing(DialogTitle) Then DialogTitle = ""
    If IsMissing(hwnd) Then hwnd = Application.hWndAccessApp
    If IsMissing(OpenFile) Then OpenFile = True
    ' Allocate string space for the returned strings.
    strFileName = Left(FileName & String(256, 0), 256)
    strFileTitle = String(256, 0)
    ' Set up the data structure before you call the function
    With OFN
        .lStructSize = Len(OFN)
        .hwndOwner = hwnd
        .strFilter = Filter
        .nFilterIndex = FilterIndex
        .strFile = strFileName
        .nMaxFile = Len(strFileName)
        .strFileTitle = strFileTitle
        .nMaxFileTitle = Len(strFileTitle)
        .strTitle = DialogTitle
        .flags = flags
        .strDefExt = DefaultExt
        .strInitialDir = InitialDir
        ' Didn't think most people would want to deal with
        ' these options.
        .hInstance = 0
        '.strCustomFilter = ""
        '.nMaxCustFilter = 0
        .lpfnHook = 0
        'New for NT 4.0
        .strCustomFilter = String(255, 0)
        .nMaxCustFilter = 255
    ' This will pass the desired data structure to the
    ' Windows API, which will in turn it uses to display
    ' the Open/Save As Dialog.
    If OpenFile Then
        fResult = aht_apiGetOpenFileName(OFN)
        fResult = aht_apiGetSaveFileName(OFN)
    ' The function call filled in the strFileTitle member
    ' of the structure. You'll have to write special code
    ' to retrieve that if you're interested.
    If fResult Then
        ' You might care to check the Flags member of the
        ' structure to get information about the chosen file.
        ' In this example, if you bothered to pass in a
        ' value for Flags, we'll fill it in with the outgoing
        ' Flags value.
        If Not IsMissing(flags) Then flags = OFN.flags
        ahtCommonFileOpenSave = TrimNull(OFN.strFile)
        ahtCommonFileOpenSave = vbNullString
ส่วนโค้ดที่ปุ่มimportตามนี้นะคะ
Private Sub Command8_Click()
Me.txt_FilePath = ""
Dim s As String
    If IsNull(txt_FilePath) Or txt_FilePath = "" Then
        s = GetOpenFile("D:\")
        s = GetOpenFile(Me.txt_FilePath)
    If s = "" Then
        If Dir(s) = "" Then
            Beep
            MsgBox "????????? " & s
            txt_FilePath = s
                    CurrentDb.Execute "DELETE FROM Donki_Receiving", dbFailOnError
                txt_FilePath.BackColor = RGB(255, 204, 0)
                Application.DoCmd.TransferText acImportDelim, "Donki_Receiving", "Donki_Receiving", (txt_FilePath), True
